show vpex ports ecp statistics
show vpex ports {port_list} ecp statistics
Description
Shows bridge port extender (BPE) Edge Control Protocol (ECP) counter information.
Syntax Description
vpex Specifies Virtual Port Extender (VPEX).
ports Specifies the cascade port attached to the BPE.
port_list Specifies the cascade port attached to the BPE.
ecp Edge Control Protocol.
statistics Specifies showing ECP counter information.
Default
If you do not specify any ports, information for all cascade ports appears.
The following example shows ECP counter information for BPEs attached to all cascade ports. In this case, there is only one attached BPE on cascade port 1:47:
# show vpex ports ecp statistics
Port   RxPkt  RxAck  RxReq  RxSeq  TxPkt  TxAck  TxReq  TxSeq  RxErr  TxErr
1:47      52      0      0    590     52     26     26     26      0      0
Flags    : (*) Active,
           (!) Administratively disabled,
           (A) Auto-calculated timer value
This command was first available in ExtremeXOS 22.5.
Platform Availability
This command is available on ExtremeSwitching 5420 and 5520 series switches, and Extreme 7520-48Y switches.
